Is this supposed to be a ground wire ?
mtnmankev
Ash Fork, Arizona
Kevin
K10, C20
383 Stroker, 350
Replacing the under dash harness and fuseblock finally.
The wires coming from the fuel tank selector switch are pink (goes to fuse block for power obviously) and a pink w/ black tracer with a connector on the end.
This is my OEM existing harness in the pic.
Is the connector supposed to go to a ground, or plug in somewhere else?
The donor harness came from a diesel model, obviously with single fuel tank, so I have to reuse some of my existing wiring, and hopefully I won't need to do any "creative wiring".
custodian
Catawba
William
C10, C30
5.3 LS, 350, 454
This is the fuse box from my 85 C10 that was a diesel, now a gas motor, that has dual tanks.
mtnmankev
Ash Fork, Arizona
Kevin
K10, C20
383 Stroker, 350
Well, I will inspect it closer, if it has dust inside, it was never connected to anything.
If it's shiny, it plugged in somewhere.
If I leave it unplugged and everything still works properly, I won't worry much.
CrazyArk just looked at his 86 and it should be a ground if GM used the same wire color codes.
akchevy86
