Ignition Coil Resistance Specifications
thomasl
dallas, ga
tom
Folks,
Anyone know what the resistance specifications are for a K10 350 ignition coil?
Wanting to test my current coil before replacing it if need be. Problem is sometimes the starter will turn, sometimes it will slowly groan as if it is not getting enough power and then sometimes it will not make any sound at all.
I already replaced the distributor, rotor and spark plug wires.
Thanks.
350runner
tx
Ceasar
sounds more like a power supply to the starter issue. have toy changed the positive power cable to the starter yet?
thomasl
dallas, ga
tom
I have not changed the positive power cable to the starter. I'll try that first before messing with the coil. Thanks.
350runner
tx
Ceasar
not a problem. also find a parts store or Wal-Mart to have the battery checked so you can know how many cranking amps are left. it will show your the strength of your battery.
thomasl
dallas, ga
tom
Thanks again. Just saw your other reply to a guy having issues with his power due to adding on Hella lights. Appreciate you passing on your insights to those in need!
Tom
350runner
tx
Ceasar
no problem i enjoy helping folks. it always helps to have a couple other opinions to help figure out issues.
You're a patient man Ceasar. If asked that question, a lot of people would be all like:
"What...are you talking about? The resistance/voltage drop across the ignition coil has no effect on how fast the starter cranks the motor!"
350runner
tx
Ceasar
This^^^ is so true and the main reason I choose to only visit this site for Chevy related threads. Thanks Jerry I appreciate it.
MadOgre
NA
NA
NA
NA
NA
lol
Now that all the gay stuff is out of the way, here is the coil resistance data (and test procedures) for the HEI system;
Resistance specs (across the primary and secondary windings) at 75 degrees F:
IGNITION COIL TEST
1. Connect ohmmeter as shown in step 1, Fig. 3, and set meter on high scale. Meter should indicate very high or infinite resistance. If not, coil is defective.
2. Connect ohmmeter as shown in step 2, Fig. 3, and set meter on low scale. Meter should indicate low or no resistance. If not, coil is defective.
3. Connect ohmmeter as shown in step 3, Fig. 3, and set meter on high scale. If meter indicates infinite resistance, coil is defective.
PICKUP COIL TEST
1. Remove distributor cap and rotor, and disconnect pickup coil leads from module.
2. Connect ohmmeter as shown in step 1, Fig. 4, and flex pickup coil leads while observing meter. Meter should indicate infinite resistance at all times. If not, pickup coil is defective.
3. Connect ohmmeter as shown in step 2, Fig. 4, and flex pickup coil leads while observing meter. Meter reading should remain constant between 500 and 1500 ohms. If not, replace pickup coil.
The images above may not exactly match your particular coil design. Here is the same procedure as done on a more familiar coil/pick-up assembly:
Coil Test
TEST 1:Remove and invert the cap, Measure between the "TACH" and "BAT" terminals , using your VOM, Set to OHMS scale, RX1 (or auto) and be sure the scale reads zero ( 0.00) It should read less than an ohm, typically around 0.5 to 0.6 ohms. Anything less or more, replace the coil.
TEST 2: Set your VOM scale to RX10k or higher (or auto). Touch the probes between the "BAT" and the carbon pickup for the coil. This reading should read between 6000 and 30,000 OHMS. Outside of that range the coil is bad, replace.
Also using test 2 as a reference, check for shorted to ground connections, by probing the "BAT" connection and the center terminal with your VOM leads. There should be infinity resistance or OL on your meter. You can also check the "TACH" connection as well. Either way, if the reading is anything less than OL, replace the coil.
Pick Up Coil Test
1. With your VOM set on the highest scale (or auto), touch one lead of your meter to the distributor body and the other lead to one of the terminals for the pick up coil (either the green or white lead. Your reading should be infinity or OL. Test the other terminal. Any reading less than infinity means the pick up coil is junk.
2. With your VOM set on RX10K scale (or auto), touch each terminal with your leads from your meter. The reading you see here should be around 500 to 1500 ohms and the reading should be steady as the wires are wiggled.
If the coil fails either test, replace the pick up coil.
How to test a GM HEI ignition module without the special module testing tool.
Note: Instead of the plug tester called for in the procedure, just pull a plug reconnect the plug wire and ground the plug against the engine. When cranking, a good spark is indicated by a bright blue arc across the electrodes also the arc should be accompanied by an audible, sharp cracking noise.
HEI diagnostic chart for a non-start condition:
SpooN
Charleston, SC
Paco
K1500
I ended up here on this diagram for a no-start. What all would you guys check?
86_chev
