Holley terminator stealth efi
davidcv383
US
Chad
Has anyone had experience with holley terminator stealth efi system?
Issue that I am having is on freeway cruising speed and I step on it the best term is it burps. It basically flutters a little then it catches up with itself and I'm gone if that makes sense.
Runs great at idle, runs great at lower cruising speed meaning say 30 mph and I step on it and it lights up the tires.
I know there are a lot of x factors any help would be appreciated.
I know there will be questions on specs of motor etc but decided to start off basic and hopefully answer the questions as they come in.
Sent from my SM-G965U using Tapatalk
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
WOT afr setting
davidcv383
US
Chad
It is currently set at 12.5 any suggestions on what to set it to?
Vbb199
Salisbury NC
Vince
I'd say 12.5-13.5 but it sounds like you have it set right.
Vbb199
Salisbury NC
Vince
Are you using one of the compliant distributors with the system? Was maybe wondering if you're getting EMI in the system.
davidcv383
US
Chad
I put in a msd pro billet 85551 distributor.
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
AE curve probably needs adjusting. Also look at ROC settings in the instructions.
davidcv383
US
Chad
Thanks for all that have helped.
Two things I adjusted.
1.Fuel pressure from 45 psi to 65 psi
2. WOT from 12.5 to 13.0
I can say it is way better, still needs a little more fine tuning but the issue that I had has been resolved.
If anyone needs help let me know. May be my first time with fuel injection but have had 24 years of working on square body's and have done some pretty cool modifications that I haven't seen done to date.
Have always been a holley carburetor person but the fuel injection has great throttle response.
75gmck25
Northern Virginia
Bruce
Does that EFI have any real time monitoring capability?
I have a Quadrajet and digital wide band AFR gauge , and I can see the mixture go rich or lean under acceleration, coasting, etc. It’s not a complete solution, but watching the gauge did uncover my misadjusted throttle linkage and a few other issues.
Bruce
davidcv383
US
Chad
Yes it does.
It shows it in numbers and color.
That is another good thought.
little boy blue
Vancouver, BC
Gino
K1500
400 sbc
Have you seen improved gas mileage? How's start up and driveability?
davidcv383
US
Chad
Gas mileage is still unknown yet.
But for drivability and startup I would say is top notch. Starting with startup, it's nice there is no more waiting for choke and it to warm up like a carb. Drivability is instant throttle response.
Any more questions let me know.
bluex
Spartanburg SC
C15
This, Acceleration enrichment is probably too high. Drop it a little in the area it stumbles an see how that helps
If you haven't driven it much I'd get the base table dialed in better before changing the modifiers. If the base table is also to rich the problem could go away as the base is corrected.
Marcoman
California
Marco
Scottsdale
Hey there, can you give us an update on how it's doing for you? Did you ever check on how the mileage is doing and performance issues?
davidcv383
US
Chad
Haven't checked fuel economy yet due to I am in the middle of taking out my automatic transmission and adding a manual transmission.
For driveability all I can say is I am very happy with it.
As far as I am concerned no more carburetors for me.
I have been a huge fan of carburetors for years because of the simplicity.
For longevity we will see how long before I have issues, none yet but I am always interested to see how long it will last before there are issues.
Todd Lemon
