Holley projection kit
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
I just found this on craigslist.
http://reno.craigslist.org/pts/2791076291.html
This is the first I have seen of this kit, it looks brilliant.
Would be ok if they had a better way to hold the injectors down, every one I have seen, they leak really bad, and are almost impossible to cure. if one was good at working with metal, I'll bet a better hold down could be fabricated, but at that point, you may as well use a rochester 454 TB
oneluckypops
Sedalia, Mo.
Luke
IMHO the only aftermarket fuel injection system the i would consider is the Edelbrock MPFI but then again the last price i seen on it was 1800 bux
Jims86
Patterson,Ca
5.7 TBI
My only issue with that one, is you can only use those small injectors, instead of regular bosch/denso types....unless you put a huge spacer on it to raise the TB.
Hard
