high beam
Gsub
Belgium
Gert
Suburban C10
hi guys,
i have a problem with my high beams, when i drive my 82 sub and swith from regular lights to high beam, the lights burn but start flashing, when i swith back to regular lights everything is fine ??
where i start looking ?
gert
VAL
TUCSON, ARIZONA
VAL
K10 SILVERADO
Your overloading the headlight switch, it has a built in circuit breaker that will make it flash when on high beams. Did you upgrad the headlights? If so, I'd look into getting a headlight harness with relays. If you didn't upgrade, your switch is bad.
twzorek
