Hi, I’m new here
270win
South Louisiana
Daniel
k15
hi from south Louisiana. I don’t actually own a square body yet. I’m hoping to get one soon though. I’m 43 and I’ve been wanting one of these trucks since I was about 5 or 6 years old. I’m ready to get one. There are a few in my area, but I’m a bit overwhelmed. What I want is a short bed 4x4 with the 465 4 speed manual. (Yeah, everyone else too, hunh). I’m willing to put SOME work into restoring a truck, but I have never restored a vehicle before and don’t want a project bigger than I can handle. My brother restored a ‘67 4x4 that used to belong to my dad and I’m a bit jealous. He poured a whole lot of work over 15 years, but he finally got it done and it’s great.
Is it difficult to swap a 4 speed into an automatic?
Is it a sin to rebadge a GMC as a Chevy?
The end result that I want is a restoration that appears factory with maybe slight changes.
animal
Lee
c10 silverado
350ish
:welcome:
Snoots
Roger
Jimmy Sierra
350 w/203
Difficulty swapping a 4 speed into an auto truck. Depends on you, do you feel your skill level will allow you to remove and replace a steering column,and the pedal assembly,remove and replace a clutch and flywheel, R&R a transfer case and transmission. If you can do these things than no it's not a big deal. Finding all the pieces might be fun. Now if you're changing badges and transmissions etc. It sounds like your going,custom build,restomod. But not restored.
Auburn, Washington
There’s a lot of 4 speed trucks out there. Juice not worth the squeeze there IMO unless you’re gettin a smoking deal on an auto truck.
And IF I was gonna swap I’d put that work to better use and find an OD trans, A833 if you can stumble on one, or a NV swap. It’s a lot of work either way, so may as well maximize the benefits.
Truck overall, of course your budget is a factor but a few tips that I try to find/live by.
- if you’re wanting a new looking interior, a truck with a “decent” interior isn’t worth more than one with a roached interior because you’re replacing it all anyways. Ideally find one that you can refurbish some of the parts like vents and door panels. Most will need a seat, dash pad and carpet regardless.
-if you’re repainting, of course rust free or as close as possible within your budget is preferred. But imo rusty body panels are the easy part, albeit not cheap to replace. it’s the whole chassis that I’d rather see clean. And I’d take some rust and Wore out original paint over 32 dents and 4 previous coats of paint.
-chassis/electrical, imo it’s obviously easier and but also generally overall cheaper and certainly less frustrating to find one that the wiring is unmolested and most/all functions working.
-drivetrain, of course budget again, but I’d take a truck with a blown engine and/or bad trans and clean vs running and rusted/banged up/hacked up, chitty repaints etc.
-short bed? If it’s gonna get re-painted, highly consider a deal on a long bed and converting to short bed imo. SB trucks apples to apples always go for $thousands more. The kit is under $500 and it’s your just hours if you can do the chassis and bodywork. If you can’t do that stuff then it makes buying an original short bed much more attractive.
-Make a list of “everything” you think a particular truck your interested in will take to get to where you want it. Add some contingency unless you have good skills and a good vision of what it will take. Add that to the cost of the truck and compare to something nicer that needs less and see where the balance is. Or use it as a bargaining chip for a lower price if you’re up to the tasks.
Even with your own labor it’s easy to be upside down on it once you dig in. And it’s very possible to find something that has a lot of the work done or doesn’t need near as much.
IMO, a 15 year or 5 year or …. Restoration is not worth it unless you just want to tinker and basically never enjoy the truck.
With some skill and knowledge it’s possible to not be upside down on the truck. But there are plenty of folks who are. That’s who you want to buy a truck from. Take advantage of that.
Like the C10 I just picked up. Dude had a stack of receipts totaling 200% of the purchase price I paid! Could I have had the same truck for less than he spent? Sure, but he took a bath and I got to cross off dozens of things that would need to be done to an old truck. Many of which were expensive and would take a lot of time.
In the end, I gave $1-2k more compared to any number of “similar condition” trucks that would need far more than $2k and a lot of hours to get to where this one is at.
Auburn, Washington
At least you’re down south so decent squares are more plentiful than the rust belt.
But, shipping a running vehicle is not “that” expensive. So see what’s out there out of your local area.
And you’re a long ways from the PNW, but there is a plethora of clean squares in this corner of the country. It’ll cost you $500 for travel and $1500-2k to ship one back home but you could find something that saves you more than 2 grand due to clean and no rust etc.
And remember it ain’t like shopping for a new used car. Each perspective buy needs to be analyzed in detail for value to a much greater extent. Unless you’re cool with just spending mo money. And more headaches.
legopnuematic
Licensed Junk Dealer
MO
Spencer
Welcome from Missouri.
270win
South Louisiana
Daniel
k15
Thanks to all for yall greetings and advice, especially Grit dog. You made some good points.
I have a good looking truck in my sights now that I’m set to look at Saturday and possibly take home. From the pictures and videos , the body looks like it’s in great shape. I don’t think it even needs cab corners or kick panels! The truck is in drivable condition right now, so can fix it up slowly at the same time while I can enjoy driving it.
I had actually considered doing the short bed conversion on a long bed. BUT I kinda hate to be the one to cut up on a classic truck, even if the long beds are less desirable to most people.
Auburn, Washington
@270win
I sort of agree with you on the cutting up a classic thing, however unless you have a pristine original original truck, these trucks aren’t even close to rare and my thoughts are, there are so many and they’re so popular that you’re not going to hurt the value of a run of the mill squarebody, not now or for decades, if you modify it.
But there’s also a lot to be said for not having a truck thats cut up or having to do all the extra work.
Good luck, hope ya find a good one.
C10Roller
