Help! Engine acting funny
ESO6200
Cali
Fabian
Hello i am new to this forum so please excuse me if theres a thread for this topic .. But im having trouble with my truck . Its a 1984 gmc 5.0 305 .. So the truck starts up but it has a rough idle and dies after a few minutes .. I have changed the fuel filter , new spark plugs & wires ,new battery im stuck as of now as to what it can be .. I have a timing gun that ill use to check the timing . Please help with suggestions
87scotty
Central il
Andrew
V20
5.7 for now
Fuel pump
87scotty
Central il
Andrew
V20
5.7 for now
Carb? Clean?
ESO6200
Cali
Fabian
How can i check if its the fuel pump? Iknoe that i have to get a pressure tester but where do i hook it up to? Also the truck stayed on when i took off the airfilter cover and had some hoses dosconencted
87scotty
Central il
Andrew
V20
5.7 for now
First thing can you hear the pump when you turn the key on take the gas cap off and have someone listen
ESO6200
Cali
Fabian
Okay ill check that out thanks. Any idea on what it can if it werent the fuel pump?
Chevrolado
McKinney, TX
Dave
V8
Which hoses did you disconnect that then allowed it to stay running??
ESO6200
Cali
Fabian
Can you view pictures? Ican go ahead and show you
Chevrolado
McKinney, TX
Dave
V8
Post them in the thread.. I'm sure it'll help everyone with a little more pieces to the puzzle. :)
ESO6200
Cali
Fabian
Will do im taking them right now
ESO6200
Cali
Fabian
ESO6200
Cali
Fabian
These are the ones ileft disconnected where it stayed on longer then having them connected . Im really stuck to as why it wont stay on. Maybe a dirty carb? Or ?
Chevrolado
McKinney, TX
Dave
V8
So by having those disconnected it will continue to run perfectly fine? Or you still get bad idle, it just doesn't actually die?
ESO6200
Cali
Fabian
The idle would be rough still but istarted it this morning and it stayed on .ithen connected them and it turned on but the it like died out probally 10 secs later .
Chevrolado
McKinney, TX
Dave
V8
Alright.. Yeah I'm personally back to a fuel pump issue I think. The added air when disconnecting those might have prolonged the ability to run or something.. But still seems to me like a fuel delivery issue. I'd go back on the trail like the earlier posters were saying about validating your fuel pump is working properly and you have correct pressure coming out.
K5Chris
