Hello new member from central North Carolina
Oldsman
NC
L.E.
Hello everyone,
I’m Oldsman, and I’ve been a proud owner of a 1981 Chevrolet Scottsdale short bed half ton four-wheel drive since 1986. It’s been parked under a shelter since 2012, and unfortunately, it hadn’t been driven much in the years leading up to that, as it had so many miles on it that it was oil fouling 3 cylinders frequently, over time the ethanol gas took its toll on the carburetor, leaving it ruined.
I bought a wrecked low mileage (32k) 1994 Buick Roadmaster with an iron head LT1 engine that I had intentions of swapping into my truck, but life got in the way, and I haven’t touched either vehicle in years. Now, at 61, I have too many projects on my plate and not enough time, so I’m looking for the simplest way to get my beloved Scottsdale back on the road.
I’d love to hear any advice or tips from fellow square body enthusiasts on how to approach this. Thank you all for your help!
ali_c20
Austria
Alexander
C20, K5
Welcome from Austria. Check the donor engine, get it running, fix what needs to be fixed and swap it in. Check brakes, fuel systems, wires and hoses and it's on the road again.
JamesSam
VA
Sam
Silverado V10
5.7 L 350 v8
Welcome from VA.
legopnuematic
Licensed Junk Dealer
MO
Spencer
Welcome from Missouri.
WFO
Texas Panhandle
Sad Sack
Nebraska
Goober
C15
Welcome from Big Red Country.
animal
Moderator
Lee
c10 silverado
350ish
:welcome:
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10, 99 Silverado
Hello and welcome from central nc as well-
Marine Corps Moderator
:welcome:
Strick
Dunn, NC
Harold
C20 Crew
Welcome from Central NC. Seems you'll need an aftermarket intake so you can 4bbl that 94 engine. Make sure it has the 168 tooth flexplate as well so it couples to your converter & starter. Keep asking questions and look at the posted forums for help also.
HS
zulander
Indiana
Edward
c30
Welcome from Indiana ! If you know someone that could give you a hand and maybe take parts in trade or if you had something else for trade and could get someone to help get it running, just an idea, good luck !!
Nborden88
