Headlights do not work
JRJ85
Bremerton, WA
Rory
Hello, new member here. We have a 85 SWB, pretty much stock. One of the issues is headlights do not work. The parking lights work, brake lights work, turn signals work, no high or low beam lights work. The switch was the original thought and we replaced that. With the brand new switch in, still the same.
We keep going in circles, any thoughts? Thanks for the help.
Boone83K10
Boone, NC
Benjamin
Did you check the dimmer switch on the floor? Check ground on radiator support?
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
You might check and.or replace the dimmer switch. It's on the steering column down behind the dash. Could also be a bad ground somewhere.
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
I'm pretty sure you've already checked it, but is the fuse blown out?
wilson79
