Headlight/parking lights not working.
Mh91344
North Carolina
K20 Custom
I have a 1986 K20 custom, my headlights parking lights and interior lights are not working. I have replaced the headlight switch and the alternator, because I thought it was going bad but tested out good. My blinkers and hazards work, I know they are on a different circuit. I’m kind of at a lose of where to go from here now. Any help would be great, thanks.
Chevyguy
Eugene,OR
Clayton
V20
5.7 Litre
Have you checked your fuses?.
Clayton
Sent from my LM-V350 using Tapatalk
Chevyguy
Eugene,OR
Clayton
V20
5.7 Litre
Clayton
Chevyguy
Eugene,OR
Clayton
V20
5.7 Litre
Clayton
Mh91344
North Carolina
K20 Custom
I have checked all the fuses and they are good. I’m thinking I have a bad ground somewhere, is there a ground under the dash?
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
Pull the headlight switch connector. Check for power on the red wire. If you have no power, you may have a fusible link blown. I don’t have a wiring diagram handy, I can’t remember where the taillight circuit gets power
Mh91344
North Carolina
K20 Custom
Pulled the switch and I’m getting no power to the red wire. Time to track down a blown fuse able link I guess.
87Chevy520AZ
