Hazards, one light
Sgt Gus
Mark
R20 3/4 ton
454ci/7.4L
Hmm, replaced turn signal switch which had new hazard switch on it.
So, waiting on broken button, but with screw in place I turned them on to ck before assembly. Just the drivers side front light flashes, not passenger. Turn signals and also fixed high/low beam, both work.
It's just the brown wire? So, new switch could be bad? But why one light and not both, or both not working? Errrr
Snoots
Roger
Jimmy Sierra
350 w/203
Make sure your connector at the bottom of the column is seated properly and check for pushed pins and pinched wires.
1987 Chevy R10
