Harmonic Balancer - super weird (at least to me)
7900_Blazer
Francis
Blazer
1st crank - harmonic balancer 'barely' rubbing on the cross-member.
Back story... I purchased this '75 Blazer from a guy in Denver as a project with my 15 year-old. Supposedly a strong motor but needed tons of other work (we've replaced: both axles, bell housing, sm465, new quarters, rockers, inner and outer fenders, seats etc...), finally ready for a test drive.
1st crank and clearly something was rubbing - turns out it was the harmonic balancer rubbing against the cross-member. I don't remember it doing that when we drove it up on the trailer to haul to Texas - but there were so many 'other' noises that it very well could have been.
We've done nothing to the engine - thought maybe the new transfer case mounts were wrong but even loosening those and slightly jacking up the transmission/transfer doesn't allow for a piece of paper to slide between the harmonic balancer/cross-member below it.
I ordered a new 6 3/4 inch harmonic balancer (the one on the truck appears to be an 8")...
Any thoughts on this? Anyone ever have this happen?
AyWoSch Motors
The Parts Guy
New Mexico
Ayden
K1500 Sierra
350ci V8
I just recently put a 350 in my 78 k30.
It's down to the bare frame, so I put the engine in first, then the trans (th350), then the transfer (np203).
When the engine first went in, I had to jack the back of it up to mate with the trans, and it was tilted down so much that it hit crossmember. After I got everything in, with the brand new trans mounts, and old engine mounts, the balancer did scrape the crossmember a little bit, but after a few months of setting in, it doesn't touch it at all now.
It only has about a 1/8 inch or 3/16 inch of clearance, but it clears, and spins over by hand with now plugs. It seems like it was just a tight fit from factory.
I'd say wait a little while and see if the mounts settle in and squash down a bit.
A smaller balancer will definatly solve the issue too.
7900_Blazer
Francis
Blazer
So two responses that I need new motor mounts... Can anyone explain?
Are the mounts bad and require replacement vs switching harmonic balancers?
Thoughts?
Itali83
Maine
Ben
K10, 'burban C10, Jimmy
If you put new transfer case mount and have old hagged out motor mounts, it’s going to sit high in the rear and low in the front. Letting balancer touch crossmember. Putting new motor mounts will lift motor up in the front where it should be and gain you the clearance again. Not sure changing balancer to a different size all Willy nilly is the best idea.
ben.
7900_Blazer
Francis
Blazer
ben.
Is this typical for a 'bad' motor mount - rubbing on the cross-member?
How much of a pain is it to change the motor mounts? - on a scale of 1 to 10, with 10 being 'super painful'...???
Snoots
Roger
Jimmy Sierra
350 w/203
I depends on the tools you have available.
I'd just put a block of wood between the oil pan and floor jack, get some tension on it (don't try to lift the engine) and then one at a time, remove the old mounts and install your new ones.
Auburn, Washington
Thoughts?
Think about the mounts, rubber cushion, 20/40+ years of wear n tear on them, I bet they are soft or pooched a little.
Combined with the new mounts in the back raising the rear and pivoting the front down slightly.
Motor mounts are fairly easy, especially if you've already R&R'd the axles and half the body.
7900_Blazer
Francis
Blazer
Thanks for the encouragement... another unexpected 'wrench in the works' so to speak but just got to lean into it...
AyWoSch Motors
The Parts Guy
New Mexico
Ayden
K1500 Sierra
350ci V8
Yup, definatly the motor mounts. Those are pretty worn out When you do new mounts, you should do them all around.
Glad that fixed it.
They're relatively easy to change out.
Snoots
Roger
Jimmy Sierra
350 w/203
I do thank you and am glad that across the miles, and no pictures, the SWAG method and my experience from the same thing happening to me, the suggestion from myself and @Grit dog worked.
But YOU did the work. Give yourself a good 'attaboy' pat on the back and WELCOME to GMSB!!!
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Sometimes the rubber dries up and becomes really messy black powder. Other times they shrink.. or they just 'pack down'.
Countless problems arise over shot rubbers (including unwanted children but that's another story)... and often it's the last thing we look at.
Mudbeast2
