Gear and tire height spreadsheet calc.
vkh
Western Montana
Var
C2500
So I made a spreadsheet that calculates displacement, compression, and piston speed and posted it under engines and performance. I then decided to make one for gearing, tire height, trans ratio, and speed and this is it. Just choose what you want to solve for, enter in your data and it'll give you the number. Worth noting that for auto trans without a locking torque converter this will be abit off since the torque converter always slips a little.
https://docs.google.com/spreadsheets/d/1n2-TR1CchG8AGzrWx_TL03CMp8Ai5gMhu9XypT-MBD8/edit?usp=sharing
Should be able to use it from this link and download it if you chose. Will work in excel and Google sheets.
74 Shortbed
It has several options for downloading, I saved it as .ods and it works great.:cheers:
vkh
Western Montana
Var
C2500
Glad to hear, I haven't shared much using Google drive so I wasn't sure how it would work.
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
Awesome little tool you wrote up there, thanks!
vkh
Western Montana
Var
C2500
Thanks, seemed like a useful little project.
74 Shortbed
Yes it was..:cheers:
vkh
Western Montana
Var
C2500
Realized the spreadsheet had been broken. So i fixed, should be good to go again.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
It just crashed my Macbook Pro... !
I'm switching out my defective hard drive next week for a digital whatever SSD. I'll try it again that.
Thanks for your hard work and sharing...
vkh
Western Montana
Var
C2500
No problem, I have fun with this kind of stuff
calredneck
Cailf.
Kerch
Good good stuff
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Should I add in a slot for transfer case gearing? I'm a 2wd guy myself so I never really think of transfer cases. Could also double for those curious about gear vendors ratios too.
Probably unnecessary. Not to many drive around in low range lol
DoubleDingo
Right where I am
Bagoomba
Carb'ed Vortec 350
Back before the internet I did all of this by calculator from a formula I got from 4-wheeler magazine. I still have a few pages of different variations for Mean Green which can now be used for Crusty Biscuit, and also a sheet for my Cherokee. It came with 3.55 gears and tiny tires, so I got bigger tires and wanted to get the cruising rpm's back to what it came from the factory and 3.73's got me there.
boarder421
