Gas truck to diesel
Jake Dewilde
Oshkosh wi
Jake
Ok looking to buy a project truck currently setup to gas 350.
Would like to go to the 6.2 diesel what all will have to change
84 M1008
New York
Wayne
M1008 K30
6.2 diesel
You will need to plumb up fuel lines, get a spin on fuel filter housing and change the radiator to a 3 core diesel type from that era. The 6.2 will have a vacuum pump, you will need to connect the vacuum line from it to your transmission modulator valve assuming it's a TH400. It's pretty simple really.
a member here is doing the opposite. he would be a great resource. havent seen his name for a while so i forgot. im sure he will chime in
72cuda440
