Fuel Tank Shields
Doppleganger
OH-MI: Just like it sounds
Now that the cab and bed are off the frame, everything is exposed. What I had wondered about before, was pretty clear - these tub like shields the tanks sit in, are just packed with mud and water. Looks like an inch of silt all around it. Cant imagine why these tanks dont rot out faster.
Anyone ever altered them - like a slot down the middle of the bottom so that water and debris can get out? Maybe a few larger holes cut in the shield?
Just wunnerin.
fast68chevy
I am the original fast68chevy
LINCOLN IL
RANDY
yep you could just open-slot them real good, to allow drain out of dirt mud water etc.. yes.. or just do away with them totally and coat the tanks with rubber under body coating,
i just did away with mine, off my tanks, on my old trusty rusty beater C20 daily driver work truck here,
i got lucky with mine.
the tanks were not rusted or anything, after having sat in a dry shed for about 20 years abandoned and untouched, and until i acquired the truck, just a couple years ago now..
before either tank managed to rust through or anything,. there was ALOT of crammed stuck mud in both of my tank shields, if you really wanted to keep the shields on yours then i wou[ld suggest taking thm off and underbody coating the tanks front ends and bottom real good then put them back on so they are at least protected from water and road salt etc.
and also modify the mounting of the shields, so that they are down a lil lower away from the bottom side of the tanks,. like a half inch, or an inch or something.,
i chose to run with no shields at all. i feel that i just dont need them on my rig.
and actually i removed and did away with my RH side tank and switch control valve solenoid assy and wire harness and all that..
I really dont need a second tank either,,,. so now i have a factory and good working 1970s dual tank hanress and switch and control solenoid valve available for anyone... parts trades or whatever hmm...
Moderator
I did away with the plastic shield on my '84. It was the #1 cause of the original rotted tank.
Doppleganger
I have 2 new tanks (for FI) and think I'll rhino-liner the bottom halves of both and ditch the shields also.
Thanks fellas!
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
Thanks fellas!
Your shields must look different than mine. Mine have a slight inverted v shape drain to the sides. Here they are sitting upside down on my back tires.
Doppleganger
Not sure - they'll be coming off sooner than later so will see. Just know that on all sides there is at least 1-2" of packed silt around it. Cant be good.
The Right side of Washington
Water drains, but one of mine was packed full of old mud around the front, rusted out the tank. I'm either **** canning them or going to "port" them so can at least get some water in there to clean out.
lukes78
