fuel filter drains out.
86chevyk20
Buffalo
Liam
when i shut my truck off my clear fuel filter drains out and makes it hard to start the truck when going to start it. is the fuel sopost to drain down? i was told its a bad pump.
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
May have a bad check ball in it. Shouldnt make it hard to start though, there is always fuel in the bowl, unless thats leaking.
towman
harrisburg pa
jay
v10
what carb are you running, if a q jet the plugs on the bottom of it might be leaking
I'd say a bad check valve in the fuel pump allowing the fuel to drain back to the tank. Common. My 84 C20 does it bad. The truck sits for more than half a day, I've got to crank it crazy to get fuel up the carb.
86chevyk20
Buffalo
Liam
its a edelbrok 600. and its a autozone brand fuel pump so maybe thats the problem lol
Yes, then that's your problem. Eddys don't have issues with draining the fuel bowl from leaking plugs. A 5-10lb electronic fuel pump solves this problem but I'd suggest a regulator to keep strain off the needle and seat in the carb. You could also get a new mechanical pump, but this issue is fairly common and likely to happen again soon. Or you can live with it. As said, mine only has an issue if I let it sit for a few hours, so once I'm out and about it's usually not a problem at all. Just have to do some cranking for the first time of the day start up usually.
I don;t miss that ****, my clear filters always did that, they never even filled all the way up while running, so I just went back to the no see through, out of sight, out of mind, lol... :shitsweak:
I still like see through. A good way to tell if you fuel pump is working or not. This on carbed vechicles of course.
mick84
