effnay
- Aug 19, 2020
- wyandotte, MI
- brad
- C10 2wd
Hello all.
I made kinda rookie mistake when restoring my driveshaft. When I pressed the yoke and u-joint out before painting it I failed to mark which end the trans yoke goes on and which end the u-joint for the rear goes. By the way, its a 84 c10 2wd Longbed.
I took some measurements from where center of u-joint to where the driveshaft starts to bulge out. It 6-1/2" on both ends, give or take. I'm kinda under the assumption that it does not matter where the yoke or u-joint goes being they are the same distance, but figured I'd see what you guys thought.
Any help would be greatly appreciated.
