Frame Swap Questions
Joshua8336
Dirty South AL
Joshua
hello guys. i came across a 1985 k5 blazer. 4x4 454 not sure on the trans. can i swap my 85 pickup body onto the k5 frame, or are the body mounts different?
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
The K5 frame is shorter. I've seen some K5s with pickup bodies and really short beds though.
Joshua8336
Dirty South AL
Joshua
how would i go about putting the front axle under my truck?
Camo
mobile
1500 extended cab 4x4
4.8 V8
youll need the crossmeaber for the engine mounts, layout adn cut the holes for the rear leaf spring . its not as hard as it sounds, It can be easily done in a day if you predrill the holes before you start the swap.
FenderBanger
