Flipped axle Caltracs?
Scruffy49
Law Enforcement Navy
Rosemark TN
Jeff
C10 swb
4.3L
Anyone running them? If so, do they actually do anything productive, or just add weight and “look cool”?
Back when I was building Danger Rangers, a Bronco 2 trac bar set was basically mandatory, but, completely different mounting system. Hooks to the front hanger and rear axle plates, NOT in place of the hanger/spring interface.
Ralph is a roach, but even with 40 years of WW2 veteran ownership and a 4.3, there was axle hop… At stock ride height…
Tennessee
Not on an axle flip but yes, they work. No more wheel hop. I set mine with a small gap so the ride is the same as if they weren't there
xm20k
Girard, Ohio
I run them it prevents axle hop and you can pre load one side to force the rear end to steer under torque.
shawn57nomad
Supporting Member Navy
Midwest
Working on mine as we speak. I'll get pictures up in the next few days for reference. Like xm20k said, helps you steer under power.
shawn57nomad
Midwest
Had to trim about 4 inches off the front of the overload leaf. This truck was ordered as a 250 with MM7/MY6 4 speed and 770# rear light duty leaf springs.
Scruffy49
Rosemark TN
Jeff
C10 swb
4.3L
Mine says 919# capacity on the camper label. 3+1 1.5” thick pack, factory 10 bolt axle, even with load assist shocks it dropped a good 7-8 inches with the flip kit and shock relocators. Spring and shackle bushings replaced with Energy Suspension red bushings, lots of their proprietery grease. I do need to remove probably 4-500 pounds of parts/tools from the bed though. Going to run 2.5” spindles, trimmed coils, swap the 4.3 for a 350.
Have a set of Z71 rear springs, pondering adding a leaf or two versus staying factory springs and track bars with the flip. If it hopped with a worn out 4.3, it’s going to have bigger control issues with a known 335 rwhp sbc…
mo4154
