Fitting of twin gas tanks
Dave M
Banned
Australia
Dave
Hi all, I'm wanting to fit twin tanks to my '76 Silverado short bed, I managed to get another tank and brackets to do the job, however l need to fit the recess in the L/H panel to mount the filler. I could weld in another section from a donor panel but they are not that easy to obtain here. Was wondering if anybody else has got around this problem with another option,
cheers Dave.
let me check to see if an old piece of panel from a long gone truck has it cut out. do you know what it would look like under the trim?
FireTruck1984
Michigan
1984 and 1984
Have you considered a Flush mount fuel filler in the bed?
Ohhhh, he meant the doors for the bed. I thought he meant switch on dash. I seeeeeee. I have a bed with two flush mount fillers, but its 1978, 79+ iirc is door. I am curious as to options, too, as Im using a passenger only bed with a driver only saddle tank, and my fender has a hole cut in it to access it... from the top.
Dave M
Banned
Australia
Dave
Thanks for your replies, I am a stickler for standard/original look bodywork. I don't want the gas filler doors from the later trucks. That would be too easy! If I could get a panel section cutout that the standard filler tube mounts to, it would be good. A flush mount filler in the bed itself isn't my thing, hard to access if your loaded. (the bed, not me!) I did think of leaving the filler neck in the inner rear wheel tub, but I am concerned about damage from rocks/gravel. Still open to ideas.
FireTruck1984
Michigan
1984 and 1984
You could graft a patch panel from a Donor truck, (although you said they’re hard to find in Australia). A new bed side with filler hole ?
Believe me... you dont want it in the bed fender thing. You dont. Unless you are okay with and understand that you could hinge an access door in that said comparment, but you would want to verify or assure that you ALWAYS have it cleared out around it so that you can put gas in. One way to do so, perhaps, is to make a small tool box over the fender well and maybe keep a spare quart of oil, jumpers, etc and when you open it, have a direct shot down to the fill cap(maybe another door) or you could buy new bedside/replacement panels... eh. New is really only justifyable when you are restoring. They are a pretty penny.
When I said flush mount I meant that old style, but i suppose its not flush with panel in the technical sense. But yeah, I have that style on an old trailer of mine. If I werent considering using it again in future, id offer to cut up... but I might have an old bedside out on my property, i can look to see if it has the kind you seek.
My truck had a dealer installed aux tank, and it looked like they had just estimated the position and used a hole saw to add the 2nd filler. I’ve since replaced the entire bed, so I don’t have a picture of what they did.
not very elegant... could always have the fill port straight vertical even with bed. looks weird af but keeps it unobstructed.
MARIOS DELIVOS
GREECE THESSALONIKI
MARIOS
C10 2WD,M1008 4WD
5.0V8,6.2 V8 DIESEL
cheers Dave.
You can buy a used fuel filler neck like mine just needs a round hole .....
Any need still present? my driver side does NOT have the hole but the passenger does.
Dave M
Banned
Australia
Dave
Sorted this problem out ! Thank you to all who offered suggestions, but after a bit of thought, over a few beers, and that is when l do my best creative thinking, l went down this path.
I made up bit of crude tooling with bits and pieces l had in the shed. (refer photo) I shaped 2 MDF pieces to match the curvature of the panel inside and out, hole sawed, (98mm inner and 89mm outer) the 4" pipe piece is used to clamp up the actual panel in between the MDF, with the 3/4" allthread running right through the centre, backed up with 8mm steel plates and 3/4" nuts. This prevents the panel distorting. The stub of 2" pipe keeps the back piece centrered in the 2" hole. Tighten the internal nut and the die presses in!
Also mask off panel prior to starting and do a sample piece before it goes anywhere near the panel. A day to make the tool and 10 minutes to drill and press.
Cracked the paint a bit, but l did expect that. I used a 2" holesaw through the panel, and the hole stretched to 2.5".
I know there are people out there who could make a much more accurate tool with right equipment, but l used what was available to me and l wanted to share this with you,
Dave
Washington
Dude, awesome fab work!
brianbones
