Engine squeal and belt wobble
ceejay
OKC
CeeJay
So recently I had to adjust the timing on my 305. Well I didn't really know what the PO did to the engine, so I rotated the engine to TDC, but when I first did this I rotated it counterclockwise and I think I loosened it, so then I ended up going clockwise to get it to TDC, adjusted the timing, all is good and well. I also went ahead and replaced the belt while I was at it. Well when I first ran the engine all good, no wobbles, nothing. Well I've developed a squeal as of recently, only on acceleration. There was not a squeal before any of this. Also, I popped the hood while it was running and looks like the belt is a little wobbly around the harmonic balancer area. I'm just taking a wild guess that is why it's squealing on acceleration. What do you think I did? Could I have loosed that pulley too much? Or is there not enough tension on the belt? Like I said, I don't recall seeing the wobbling, and there definitely wasn't squealing when I first did all this.
82sbshortbed
Why like that?
SE Texas
Doug
1500 shortbed, 1500 longbed
I'd tighten the belt. Think that'll fix the squeaking problem. Mt new alt belt did that. Little more tension and it went away.
it takes a lot less force rii rake tension off a belt than to put on it. Belts require a retension after "seating" into the grooves and a small amount of stretch occurs. this is why there are two belt tensions listed in the manual. for new and old belt. Ideally, dayco and gates say 3-5 minutes run time and then retension on a cool belt to spec is what they recommend with periodic adjustment
wshoneybadger
