electrical issue no gauges key works?
12v85k30
Ohio
Des
k30
5.9L 6bt
Ive stupidly over loaded my fuse block with keyed hot assessories like fans and fuel pump. I dont really know where to start truck starts and drives, no turn signals or gauges. Brake lights and head lights work but im lost
Any help appreciated
FRANKENTRUCK
By The Sea
Pierce
C10 Deluxe Stepside C10
350 with 350 Turbo transmission
The first and most obvious thing to check is the fuses themselves. Have you checked your fusible links? Also check the wiring harness for a fried or frayed wire.
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
K-10
350/SM465/NP205
Get a few relays for your fans & lights, that way your fusebox taps aren't carrying 30 amps, just switch signal for the relay.
My fusible link at the alternator feed to the cab junction block fried on me. There is also a fusible link on the junction block itself on mine, not sure if you have that or not.
Covington, WA
350; 700R4
My gage/idle fuse blew because of a bad ground under the driver side AC vent here:
Mavric16
