Dual fuel tanks
moosecholak
Munford, TN. (Memphis)
William
R10
I have a 1987 Chevy R10. It's getting no gas. From EITHER tank. Changed cab transfer switch. Not that. Changed fuel transfer valve under truck. That's not it. HELP
CSFJ
Are you getting power to the pumps? Can you hear them cycle on when you turn the key?
hatzie
k20
Fuel pump relay?
Is the dash switch or fuel pump relay getting power?
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
That would be my thought as well...bad relay or no power to it. My fuse popped for my fuel pump relay. It would crank over, but not start. I was baffled until I realized that the pump wasnt "buzzing" when the key was turned to the acc position.
Shak379
