Drive shaft help
joneswyatt94
gilmer, TX
wyatt
R10
I have a 1986 r10 single cab long bed 2wd. It had a turbo 350 trans originally but someone swapped a 700r4 in to it. the drive shaft got bent from someone loading it with a forklift and now I need a new one but do not want to spend $500. will any chevy single cab long bed driveshaft work that had a 700r4 and was 2wd? something such as one out of an obs truck or does it have to come out of a square body.
Tank6x2
Edmonton Alberta Canada
Kurt
C30
350, TH400.4:10 gears 2WD
Figure out your spline tooth count and overall length, Go to the auto wrecker they should be able to hook you up
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Pretty sure the u-joints changed between the obs trucks, the 80's squares have a factory "3r" u joint.
The 700r4 is a couple inches longer than a th350, although I'm not positive on the 2wd setups.
