Door closing by itself
Mr87
Jerrit
I wanted to ask if anyone else has experienced the following problem. My driver side door will not stay open but my passenger will. I tried looking at my passenger door as a reference but couldnt find any difference in the two. Does anyone have any ideas or know of a fix to keep my door from closing on its own? Thanks
Stroked
Beloit, Kansas
Jared
It's probably missing the spring. It's shaped like an S and most of the time they break and fall out. My K10 is the same way, ps door works great but the ds door won't stay open.
You can buy just the spring, but I'm not sure how hard it is to install.
85SWB
Central NJ
I had the same problem with my ds door. I couldn't find just the spring anywhere online. Ordered a repo hinge and popped it out
Stroked
Beloit, Kansas
Jared
LMC sells the spring by itself. I've been debating on just replacing it or the whole hinge.
Sent from my iPhone 4s using Tapatalk
Tyger13us
BFE,Ut
Jeff
450hp/357cid
Id do the whole hinge,, there a bitch to put a spring on them with the door on,, it can be done though, ive seen um with the rollers missing too, and id bet the bushing would need to be replaced also,, so just do the hinge and be done with it..:beatdeadhorse5:
jake wells
Can i be me?
Brownsville Kentucky
jake
custom deluxe 10
just replace the whole hinge because they are always bad on those trucks usually the pin and bushings cause more problems than the spring.
Moderator
I guess I've been lucky because all of my hinges have still had the tension springs on them, except for the '84, both of those are broke.
dan86
