Disconnected fuel line in engine bay
13matsc
Norway
Mats
C2500
I have this plugged line that has been there as long as I’ve owned the truck.
It goes back to the dual tank switch in the rear. Anyone know what this used to do? Both my tanks work, and there is a return line on the fuel pump itself.
Looks like a vent line to the charcoal cannister. I'd want to know how your tanks are venting. I usually tell people that aren't running the tank vent to the cannister to plug the hose with a clear plastic fuel filter. That way the tanks can breath but dirt and bugs can't get in the vent line.
Ken B
indiana
ken
Ricko,
I really like that idea.....I am considering removing all the smog stuff and the vapor canister that has not been properly connected for a while. the fuel filter is a genius idea.
13matsc
Norway
Mats
C2500
After some googling that seems like the correct answer.
I guess my tanks aren’t venting… Do they need to?
I like your tip! What about moisture etc. with the end open?
Yep the charcoal cannister is supposed to help keep moisture out of the tank. Ideally you'd replace it if yours is missing,ir hook it up if you have it
Ken B
indiana
ken
So is there benefit to running that fuel vent line to the canister ....if its not hooked up to the carb ?
You'll hook the cannister to the carbureator,it's simple tee into the pcv line and hook up a ported line to open the purge valve.
13matsc
Norway
Mats
C2500
What would be the major drawbacks of having it plugged like mine is now?
I have an aftermarket carb and intake.
As fuel is drawn out of the tank through the fuel line to the carburetor, air has to enter the tank to replace the fuel. And when the fuel expands during a warm day, you need to allow air to escape from the tank.
The vent line and charcoal canister allows the air to go in and out of the gas tank, and the filter mechanism in the canister traps the vapor, and then periodically vents it into the carburetor.
If you use vented gas caps, that will also allow air to enter and vent from the tanks. You might smell some gas if you stand near the fillers, but it should work fine.
Your tanks won't vent properly unless there's a leak somewhere in the evap system such as a vented cap. You will draw a vacuum in the tank and starve for fuel. Properly setup the charcoal canister allows the tank to breath,helps keep moisture out of the tank,and fumes out of your garage.
c10dang
sacramento
Bryan
I have mine going to a filter but its starving fuel when it gets to 30 mph causing a stall. Could it be because my gas caps arent vented?
As long as the vent is clear all the way to the tank and your filter is not clogged you shouldn't need a vented cap. Are you the same guy I told to blow through the line sure it's clear?YOU blow through the line not 100psi compressed air through the line.
13matsc
Norway
Mats
C2500
I ended up connecting a fuel hose and routing it back and ending it just under the driver side door.
The best solution would probably be to disconnect the line at the tank switch and remove it, with just a small stump left and a small baffle or filter.
duncan_schawalder
