Dash Alignment
maxtwms
Alabama
Max
Hey Guys - I may be poor at search function but I cant be the only person to experience this. The top/left side of my dash and instrument gauge bezel have large gaps in them. This is the case on my K10 and K5. Pretty sure the dash is new on the K10 and original on the k5. Does anyone have any tips to get these to fit nicely? Every squarebody Ive worked on has had issues with the screws in this left side location. I know they're not going to be perfect but there has to be some improvement...Any help is appreciated. Ill try to get pictures today
maxtwms
Alabama
Max
Doesn't look that bad in the picture but I'm sure some of you can relate.. maybe I need some nut clips on the padded part of the dash for the screws to grab onto? There's certainly something missing.
Sent from my SM-G988U using Tapatalk
Jeff Lewis
Missouri
Jeff
Aftermarket. Thats the best you can do. Doesn't fit exactly. Don't worry....Be Happy.
Raider L
Shreveport, LA
William
@maxtwms,
I don't know, man. It seems that with the padding like it is from the factory, after many years sitting in the sun, I think you should expect some shrinkage. Mine isn't exactly tight.
The inside curvature of the dash where the panel of the gauge cluster just sits up against a kind of a flange with the nut plates on it. Mine just screws up against that flat lip the dash has surrounding the opening for the cluster panel. It looks kinda dark in the photo but it's sitting up against that lip.
86 SCOTTSDALE
Oakham MA
Armand
I found a slightly longer screw worked better in that position.
Jwernatl
Senoia, GA
5.7ltr
Mine was same - my aftermarket I ordered was not the best - I hate it. I used the right screws and clips.
It's just not the same. Nobody knows it except me.
AyWoSch Motors
The Parts Guy
New Mexico
Ayden
K1500 Sierra
350ci V8
I have 4 Squarebodys, all of them original dashes and gauges bezels, non of them fit right. They all look like yours or worse.
I think it's a case of they never fit quite right, but after 30 to 40 years in the sun, the vinyl just shrinks a bit, and makes it worse.
If it's old, and the vinyl is hard, you could take a dremel and grind away some of the material at the corner of the dash and smooth it down, so that the bezel sits a little deeps and straighter, or you could file down the edge of the bezel to make it a little smaller. Not enough to notice. And you could try a longer screw, but dont torque it down too hard, you'll strip out the plastic hole it goes into. I've made that mistake.
Rudy Mienert
St. Petersburg, Florida
Rudy
Blazer
Which aftermarket did you get?...Im searching for a nice pad, and don't want to be disappointed.
86c10twotone
MD
Roy
Trying to install a new pad today from LMC and the clip area to the right side of the right defrost vent is to high causing the dash to sit up high in that area .
TPISly-C10
Boucherville QC Canada
Sly
C-10 shortbox
LQ4 6.0L
the most important is to aling the 2 top long center scew, after that check fit with a another long screw on top left and secure backing speed clip that the best i can do with mine to fit ok ish ;)
86c10twotone
MD
Roy
How much did you have to trim across the front where it hits the windshield rubber? Does it sit under the crown of the rubber or just but up to it ?
Rutzie
MN
Brad
V3500
I just installed a LMC one today myself. Exact same problem.... Fought with it all afternoon, thought I maybe had a clip out of place, but not the case! Looks really wavy against the windshield gasket. Did you figure out a fix for it?
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Factory. Thats the best they can do. Doesn't fit exactly. Don't worry....Be Happy.
waterpirate
delaware
v10
5.7 tbi
Same here. I installed the lmc pad and the right corner looks like $hit. Longer screws for the instrument panel helped a lot, but not perfect.
wilson79
