CS144 alternator charge wire question
Mobius
Fayetteville, AR
c10 Heavy Half
350 SBC
I’ve seen that one or more of the wires/cables need to be upgraded when changing from a stock alternator to a higher amp unit like a CS144. Exactly which wires do I need to change/upgrade? Just the one that connects to the back of the alternator? Where does that wire go on a 79 GMC?
Arkansas_V8
Proud Redneck
Springdale, Arkansas
Brent
V20 Suburban
Assume its the same as my 88 Suburban.
1 to the battery, 1 to the junction on the firewall.
If not- it only goes to one of those places.
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
Or from alternator to starter. Probably how it was on a 79.
I’d go with a 2ga wire for the new charge wire.
Mobius
Fayetteville, AR
c10 Heavy Half
350 SBC
2 gauge from the back of the alternator to the battery? Or to the starter? Does it matter? Also, that seems awfully large, considering the stock wire can’t be more than about 8 AWG. I understand the cables going from the battery to the starter and the frame have to be beefy, but even the Powermaster 150 amp charge wire is 6AWG, iirc.
Arkansas_V8
Proud Redneck
Brent
V20 Suburban
6 will be fine. Trace the wire, and replace it. Or bring it to me, and I will help you.
Thats 6, and its been fine.
Arkansas_V8
Proud Redneck
Brent
V20 Suburban
I have like 8 foot of 4 gauge you can use. Just buy the lugs for it.
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
I have a 175 amp alternator and I just like overkill like that. 2ga is what I run.
Look up wire gauge amp chart and go from there.
Arkansas_V8
Proud Redneck
Brent
V20 Suburban
What are you running, the whole darn tailgate party? Lol
Mine is like 105 amp
Inverter
Winch
Lights
Electric fans
And usuals.
You could damn near run all my stuff at once.
Mobius
Fayetteville, AR
c10 Heavy Half
350 SBC
Cool. So the wire that currently runs from the alternator into the harness, and I assume to the starter, isn’t necessary? I can just run a larger one from the alternator to the battery? Or should I leave the one connected to the starter?
Arkansas_V8
Proud Redneck
Brent
V20 Suburban
Battery to starter, battery to alternator, starter to junction block, alternator to junction block. Those are what are necessary.
Mobius
Fayetteville, AR
c10 Heavy Half
350 SBC
I guess I have some looking around to do. I don’t know where thins junction block is.
Arkansas_V8
Proud Redneck
Brent
V20 Suburban
Be like this on the firewall. Or some iteration of that.
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
Inverter
Winch
Lights
Electric fans
And usuals.
Not much, but I’ll never run out. Like I said, overkill. I do everything to the umpteenth degree. I have slight OCD.
Nice thing about my alternator is how many amps it makes at idle. That’s where the biggest difference is.
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
Not sure what year GM went to the firewall junction, but before that it was at the horn relay.
Arkansas_V8
Proud Redneck
Brent
V20 Suburban
You could be absolutely right. It has just been so long since I have seen one not upgraded to the later model setup.
