changing engine mountes in truck?
86chevyk20
Buffalo
Liam
I know i should of replaced my motor mounts before i installed engine i forgot lol i was to excited to get it to run haha anyways..
can i change them in the truck or do i have to remove the engine? can i use a jack due to not having a cherry picker??
Irishman999
Safford Arizona
Jason
K-1500 High Sierra
Get a piece of wood and jack up the engine by the harmonic balancer or somewhere on the oil pan. You can do it with the engine in.
Swims350
Logan WV
none
or hook the cherry picker or whatever you used to pull/put in the motor.
If the mounts are still in decent shape, just leave them be.
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
K-10
350/SM465/NP205
I would jack it up at the oil pan, not the harmonic balancer. Just my $0.02
animal
Lee
c10 silverado
350ish
X2
Be sure to use a block of wood or something between the jack and the oil pan to distribute the weight and not dent the oil pan.
Swims350
Logan WV
none
guys if he has or had a way to put the engine in why not use it? like a cherry picker, no worry on dented pans or damaged dampers.
animal
Lee
c10 silverado
350ish
I agree cherry picker would be the preferred solution but he states in the original post he doesn't have access to a cherry picker now.:wave:
Swims350
Logan WV
none
LOL you gotta be kidding me, sorry guys no wonder, I missed it lol. Now don't I feel stupid. I completely overlooked that part.
But yes use a block or brick under the oil pan and raise it up.
animal
Lee
c10 silverado
350ish
No apology needed! I had the same thought then went back and read the post again.
Hard
