changed distributor an bad things
r.booser
Knoxville
Ron
So I changed my distributor on my 85 c20 350 today. Had the number 1 piston to top dead center. Hooked it back up, tried to start an after a few roll overs a big bang came from the motor. What the he'll did I do wrong? Needless to say I'm a little lost on what I did wrong....HELP ME!
78bigblock
North Carolina
Adam
What kind of bang? Metallic or did it doing like a backfire or what?
r.booser
Knoxville
Ron
Metalic, I bought a distributor off ebay. Could it be bad an making that noise or is something wrong?
87ChevyR10
Kansas
NA
NA
NA
If the dizzy timing is severely off, you may have caused internal engine damage. Did you mark the dizzy before removing it? If not, then you had no way of knowing how to re-install the new one.
I have a feeling at least 1 piston is ruined.
r.booser
Knoxville
Ron
I couldn't mark the dizzy, I was changing it. I put it to top dead center and dropped the new one in like your supposed too.
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
It's possible you are 180* out on the distributor. Pull the spark plug for #1 cylinder and crank the engine over with your thumb over the spark plug hole, and when you feel the compression blow your finger off the hole, crank it over a little bit further until you are at TDC on the balancer. This is TDC on the compression stroke, as opposed to the exhaust stroke. Then you can stab your dizzy with the rotor pointing at the #1 terminal (cap off the dizzy).
r.booser
Knoxville
Ron
That's exactly what I did. That's why I'm so confused. I'm going to check it all again tomorrow and put tan other dizzy in. I just checked an the new one feels loose, like the shift isn't fitting snugly. I'm hoping this is my lesson for buying cheap Japanese crap.
r.booser
Knoxville
Ron
I was 180 off, you were exactly right. Man what a rookie mistake. Thanks guys
Stroked
Beloit, Kansas
Jared
So you put the new eBay distributor back in rotated 180* and everything is good now? Or you put the old dizzy back in?
r.booser
Knoxville
Ron
same distributor I purchased off ebay. I was just 180 off, had the piston TDC just not on the compression side. Rookie mistake I guess. I spoke with a few people and they said it sounds like I was just 180 off too. So I thought I would try that first. Fired right up. I have a few little things to change and hopefully then she will be road worthy. Last owner looped the heater coil, hopefully it doesn't leak when I hook it back up tonight
Stroked
Beloit, Kansas
Jared
Glad to hear it was something simple and that the dizzy worked out good.
r.booser
Knoxville
Ron
me too! I had a mini heart attack I think. Felt more stupid than anything. Might be the dumbest mistake I have made working on a car. But this is my carbureted motor so I should have expected it.
r.booser
Knoxville
Ron
I'll have to figure out how to do a build thread and get that started.
ruggedly
