can you tell me what this is in my picture?
donkeypunch
Surprise, az
kelly
v30 cc
ok i am trying to troubleshoot an o2 code (1-3) i think it may be the result of some other electrical issue as i have replaced the sensor with a new bosch, so i have found a few cut wires and will start with this one.
this is from some electrical connection between my tbi and the distributor. it was clearly cut but not sure what its for?
thanks as always for any help.
donkeypunch
Surprise, az
kelly
v30 cc
This is from some electrical connection between my tbi and the distributor. It was clearly cut but not sure what its for?
Thanks as always for any help.
i should note that im assuming this is the coil but where would this wire go? I see nothing in the area for it to connect to.
smurph20
Clyde, Arkansas 72717
Brad
350/SM465/NP208/4.10's
yes sir thats the wire on my S10 that runs the tach and i have the same coil also if you look it has a lil bit of green wire still on it which is what a aftermarket tach signal wire color is
Agreed, that's the tach signal wire.
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
Aftermarket tachometer?
yup, thats the tach wire.
the only wire for the o2 is a purple wire that goes straight to the ecm from the o2 sensor, make sure its no against the exhaust manifold. also, if you have a smog pump, the ecm will throw an o2 sensor if there is a fault with the pump or the diverter valve.
donkeypunch
Surprise, az
kelly
v30 cc
OK good info....So the diverter valve is on the pump? Have you heard of these trucks being brand sensitive? I thought I saw somewhere a guy was able to stop his o2 code by buying a delco sensor. Its just another $50 so I am reluctant to do it.
Jims86
Patterson,Ca
5.7 TBI
The diverter valve is usually mounted above the air pump, and has a 2wire connector,with a pink(power wire,12v) , and a brown or tan wires(computer controlled ground from the ECM), and has a vacuum line running to it. they are pricy to replace, unless you can find one at the wrecker.
As Far as sensors, and spark plugs, many of us have found that it is worth the extra scratch to stick with delco, but you can use any aftermarket brand if the dollars are tight, just dont be surprised if you have a rougher than usual idle, and different mpgs.
Bigskygearhead
