c20 control arms
jeremys14
texas
jeremy
will c30 control arms work on a c20?
Bagged Dually
Joplin,Mo.
Kris
CUMMINS 12 valve
I highly doubt you really still need this info if it's even correct, but I've heard that all half to 1 ton control arms are the same on 2wd trucks. If I'm wrong someone please correct me and I'll learn something also.
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
For future reference on lower control arms:
C20-C30 w/o F42:
CHEVROLET FORWARD CONTROL 71-72 30 Series; 11000 lb rear axle
CHEVROLET FORWARD CONTROL 71-72 30 Series; 7200 lb rear axle
CHEVROLET FORWARD CONTROL 71-89 20 Series
CHEVROLET FORWARD CONTROL 73 30 Series; removable carrier
CHEVROLET FORWARD CONTROL 73-78 30 Series; non-removable carrier
CHEVROLET FORWARD CONTROL 79-84 30 Series; drum rear brakes, SRW
CHEVROLET FORWARD CONTROL 85-92 30 Series; exc. HD front susp; drum rear brakes, SRW
CHEVROLET FORWARD CONTROL 93 30 Series; exc. HD front susp; drum rear brakes, SRW, w/o 9L6 brakes
CHEVROLET VAN 72-78 30 Series
CHEVROLET 20 PICKUP 71-88
CHEVROLET 2500 PICKUP 89 VIN models "R/V"
CHEVROLET 30 PICKUP 71-72 11000 lb rear axle
CHEVROLET 30 PICKUP 71-72 7200 lb rear axle
CHEVROLET 30 PICKUP 73-80
CHEVROLET 30 PICKUP 81-88 std duty susp
CHEVROLET 3500 PICKUP 89-91 VIN models "R/V", std duty susp
GMC 2500 PICKUP 71-87
GMC 2500 PICKUP 88-89 VIN models "R/V"
GMC 3500 PICKUP 71-72 11000 lb rear axle
GMC 3500 PICKUP 71-72 7200 lb rear axle
GMC 3500 PICKUP 73-80
GMC 3500 PICKUP 81-87 std duty susp
GMC 3500 PICKUP 88-91 VIN models "R/V", std duty susp
GMC FORWARD CONTROL 71-72 3500 Series; 11000 lb rear axle
GMC FORWARD CONTROL 71-72 3500 Series; 7200 lb rear axle
GMC FORWARD CONTROL 71-89 2500 Series
GMC FORWARD CONTROL 73 3500 Series; removable carrier
GMC FORWARD CONTROL 73-78 3500 Series; non-removable carrier
GMC FORWARD CONTROL 79-84 3500 Series; drum rear brakes, SRW
GMC FORWARD CONTROL 85-92 3500 Series; exc. HD front susp; drum rear brakes, SRW
GMC FORWARD CONTROL 93 3500 Series; exc. HD front susp; drum rear brakes, SRW, w/o 9L6 brakes
GMC VAN 72-78 3500 Series
SUBURBAN 20 71-88
SUBURBAN 2500 71-91
C10:
BLAZER/JIMMY (full size) 73-78
BLAZER/JIMMY (full size) 79 exc. 6.50x15 tire and 10x15 tire
BLAZER/JIMMY (full size) 80-82
CHEVROLET FORWARD CONTROL 73 10 Series
CHEVROLET VAN 73-74 10 Series
CHEVROLET VAN 73-74 20 Series
CHEVROLET 10 PICKUP 73-78
CHEVROLET 10 PICKUP 79 exc. 6.50x15 tire and 10x15 tire
CHEVROLET 10 PICKUP 80-87
GMC 1500 PICKUP 73-78
GMC 1500 PICKUP 79 exc. 6.50x15 tire and 10x15 tire
GMC 1500 PICKUP 80-87
GMC FORWARD CONTROL 73 1500 Series
GMC VAN 73-74 1500 Series
GMC VAN 73-74 2500 Series
SUBURBAN 10 73-78
SUBURBAN 10 79 w/o 10x15 tire
SUBURBAN 10 80-88
SUBURBAN 1500 73-78
SUBURBAN 1500 79 w/o 10x15 tire
SUBURBAN 1500 80-91
Yep, C10 is different. C20 and 30 are the same to the best of my knowledge, and it appears by Retro's data reference the 20 and 30 are the same.
I think the biggest difference is how they mount. C10's have normal rubber bushings, while C20 and C30 have these big hex nut pivot things.
Hard
