Blinker bulbs stay on
Bacon
I'm doing a '90 electronic instrument cluster swap and I'm 99% sure I have the connector done correctly. My problem is both instrument blinker bulbs stay illuminated with the key on, the fuel guage worked properly for a moment and now does not, the illuminating background lights only work with headlights OFF.. Also speedo doesn't register anything. Volt gauge moves but isn't correct, fuel moves but isn't correct, temp moves but not correct, oil pressure is not correct. Help
Georgeb
Wisconsin
George
K10 Burb Z71
Grounding issue?
74 Shortbed
Yep, check all grounds first..
wilson79
