Anchor Plate Dimensions
LateOnTheBrakes
5.3-Swapped 86 CUCV
Virginia
Joshua
CUCV
What are the anchor plate (spring perch?) hole dimensions? I don't know if the plates and the same between the 1/2, 3/4, 1, and 5/4-ton varieties. My truck is the 5/4 but has 1/2 ton axles. I think the anchor plates are for the Dana 60 front. I need to be able to pick the right U-bolts. It looks like there are two or three different U-bolt widths.
My truck has a 1973 Dana 44 in the front so there are not the two studs that need to mount to the differential.
Jawzjeep
Honk if parts fall off
Washington
Joshua
Suburban
84 k20 (3/4 ton 10 bolt) plates are 3 3/4 center of hole to center of hole. The holes for the U bolt that goes around the cast section is Center to Center of hole 4 1/4
78 k5 (1/2 ton dana 44) is the same.
91 Suburban (3/4 ton 10 bolt) is the same.
Hope this helps.
FenderBanger
