all time 4 wheel drive
hoagster
Air Force Supporting Member
California
K10, 1500
5.3l
I'd find all the VIN numbers and see if they match up after @buckets description of your truck. And maybe say high to the group, how you got the obtained it, and more pictures. Some history and did I say we like picture lots of them.
There is a VIN number on top of the frame just aft of the power steering pump. There is also a date and time stamp of the side rail of the frame by the passenger side gas tank that will tell you the year of the frame. That should give some more idea of what you have.
Definitely not an ‘85 truck. If they mixed and matched between years and did not notify DMV it may be difficult to get a valid title.
Older trucks had a shorter VIN, it was not displayed in a window in the dash bezel, and they usually can’t be easily verified as valid with newer online VIN checking tools. An ‘85 would have the longer VIN (now standard) and I think it’s visible in a window in the dash pad.
goldpack
Adirondacks, NY
Donnie
GMC C2500 Camper Spec.
350 with 350 3 speed
Full time 4wd= guaranteed to find the wheel with the least traction and f*ucking send it all there..
so...a 1970s gmc full time 4wd sucks balls that bad ? = "from the wheels that grip, to the wheel that slips"?
77Dmax
vt
Joe
I had a 77 blazer for awhile. It was kinda unpredictable in the snow. Sometimes the front would spin when i thought the rear would or vice versa. It was fine when locked. It also got the worst fuel mileage...
Safetyguy
Central Coast, CA
Greg
K20 Scottsdale Camper Special
Bought my '77 K20 new. One of the first things I di was put in a Doug Nash (4/2?) part time conversion kit. It replaced a shaft and some gear in the transfer case and came with Warn hubs. It was so much better driving on paved roads and in town without the front wheels engaged. 4WD, just lock in the Warn hubs and pull into 4WD. Easy peazy.
I don't think they have been available for quite some time; maybe others are still made?
Old Guy Bill
KY
Bill
This Forum gave me the info I needed when I began the rebuild of my '78 equipped with the 203... I had no idea about that era of TCs, and how they operated.
I replaced it with a 208 and added TruTrac diffs
Sierra_87
