Aftermarket gauge question
Linville33
Clinton, IA
Justin
K20 Scotsdale
SBC 400
Quick question for everyone, if I buy a mechanical oil pressure gauge how could I put it in the stock position? Don't want to ruin the printed cluster.
Sent from my XT901 using Tapatalk
Green79Scottsdale
G.R. - MI
Bob
Why do you want a mechanical oil pressure gauge? Does yours not work?
Linville33
Clinton, IA
Justin
K20 Scotsdale
SBC 400
Mine works its just I question its accuracy.
Green79Scottsdale
G.R. - MI
Bob
Oh. Why do you question it? What is it showing?
Green79Scottsdale
G.R. - MI
Bob
To answer your original question, it could be kind of hard to run an oil hard line into your housing. IIRC, the printed circuit covers the entire backside. I don't know if it will still work if you cut out a portion to clear your hard lines. Maybe you could come in from the top or bottom? I don't know the clearances around the cluster.
I would say to stay with your electric gauge. Maybe find someone with an aftermarket gauge that is known to be accurate, and hook it up simultaneously with yours and compare them. For piece of mind you could get a new sensor and see if it registers different than your current one.
Linville33
Clinton, IA
Justin
K20 Scotsdale
SBC 400
Mine reads 30 constantly sometimes 45 sometimes 15 doesn't move with throttle.
pistol85
