icebones
- Aug 11, 2012
- duff
- jake
- k10
Im doing a restoration on my old 1980 k10 chevy. I was wanting to add a second fuel tank to the passenger side. When i bought it years ago it had a factory 22 gallon (i think) fuel tank on the driver side. I noticed it had all the mounts for a secondary tank on the passenger side. Would it be possible to simply install a secondary tank from a junk yard and splice into the fuel line before the fuel pump, routing the fuel lines inside the cab, and mounting some sort of valve under the seat so i can switch between the right and left tanks? with all the lines running inside a braided steel outer hose to resist abrasion and damage. The whole set up will have lines for each tank running inside the cab, a valve to select the tank, and a single fuel line from the valve to the fuel pump. Sort of a similar set up to the gas valve on most atv's and dirt bikes just on a larger scale. Bad idea or no?
