87 body 77 frame trouble.
kapnhook
ohio
jason
k30
ok a few years ago i put a 1987 1/2 ton body (cab,bed and clip) on my 1977 3/4 ton 4x4.
now the problem is the body has never lined up corecty,i think i used the ruber mounts and such from the 77 3/4 ton.
what ruber mounts shoul i have used,is there spacers i should add?
any help would be great thanks
You did the right thing, use the mounts that match the frame. But if you didn't replace the mounts, you probably have fitment issues because they are worn. If needed, you can also shim the body mounts in places.
robracing85
