8.1 4l80e swap
87silveradok20
Ohio
Levi
Silverado k20
Ok, so this is going to be my questions/ build thread for this project. I have a 1987 k20 that currently has a 350/th400. I am wanting to swap this out for an 8.1 and 4l80e. At this point I have bought nothing for this project but plan to have it done by spring. I am not planning on any mods to the 8.1 right now except maybe a tune. I have a budget of around 5k to do this and will be documenting my costs. Hopefully this thread will contain a lot of Info and can help anyone thinking of doing this in the future. To start off, is there anything special to watch for when buying an engine and trans? Below are some pictures of the truck
ajd89
Central Michigan
andrew
Wow nice truck and shop! I will be watching to see how it goes for you as at some point this maybe an option for my crew cab!
ajd89
Central Michigan
andrew
Dirty Larry over on the 67 to 72 Chevy site has put two l8.1 in one in a regular cab one in a Suburban there also is a PDF file if you search Google of a guy that put one in a crew cab 88
twinturbo427
Florida
Phil
Suburban
Some quick notes I found doing the same searches.
1) The accessory brackets from a van chassis place the a/c compressor high, so no frame mods required.
2) the fuel map for the 8.1L is the same as other LS engines. It just uses bigger injectors.
3) the egr hits the pinch weld ON THE FIREWALL. AN ALLISON trans is tight in the tunnel. (That is why a body lift came on the 2500hd, like my 2007, from the factory.) I know it is not the same body style, just a reference.
4) Torque management is a blessing and a curse. Blessing fir real world driving and easy on parts. A curse when you need to blow a Stangbanger off the road. :)
Following your build. If I wasn't working on Big Rhonda today, I would post more.
yevgenievich
Viktor
sad
very sad
less sad
Van brackets are a preference but they are hard to find. The tunnel fitment issue is only with allison transmission.
twinturbo427
Florida
Phil
Suburban
Yes, absolutely right about the Allsion trans!
twinturbo427
Florida
Phil
Suburban
Ok, so with a 4l80 I should be good without a body lift?
The egr still hits the pinch weld. Should be able to work around that.
87silveradok20
Ohio
Levi
Silverado k20
Could I remove the egr and put a block off plate on?
fmxr47
US
Justin
My 6.5td has a 4l80e behind it with zero clearance issues. It has a stand-alone TCI controller which I could adjust the transmissions drive ability with, if I chose to.
And this is in an 86 not a newer truck.
87silveradok20
Ohio
Levi
Silverado k20
Ok I should be good then I’ve never heard of having trouble with them.
4WDKC
Southern Florida
Kacy
Hey that's how my truck should look when done, if it ever gets there. You will need to lengthen the rods for the 4x4 shifter to make up for the difference with the 4l80. I have seen some posted that claim low oil pressure so a low mileage one maybe the better option unless you want to refresh one up.
87silveradok20
Ohio
Levi
Silverado k20
I’m looking for a low mileage block, but i know on the ls motors there’s an o ring that goes bad and causes low oil pressure. Is there something like that on these motors?
4WDKC
Southern Florida
Kacy
Not sure still leaning about them myself..DirtLarry on www.67-72chevytrucks.com would be the guy to talk to as he has rebuilt at least one. I am also unfamiliar with the internals of an LS.
rogueakula
