nabeshin
functioning lunatic
- Jan 23, 2020
- Cozad, Nebraska
- Grae
- K10
My 400 has the BBC radiator. Siamesed cylinders need more cooling capacity, it seems. Has the trans cooler on the side below the cap.
My shroud is one piece though. It might not be original. Seems to fit poorly cause it is warped.
I had to have my radiator fully rebuilt since it was corroded internally and plugged with gunk. That all came loose and leaked when I flushed it. The rebuilder couldn't plug all the holes and still provide cooling so a new core was needed.
The truck moved regularly since it's retirement in the mid 2000s, but essentially sat that whole time. So the coolant was no longer preventing corrosion.
