73 rear end
Van-73
Delano
Ivan
So I'm new to the forum...having trouble with my 73 3/4 ton. Just did a diesel swap on it,I went from a 454 to a 6.2 diesel but having tuable with my top speed. I'm gettin about 50mph top speed on my 4 speed manual. Just asking for help to figure out what I need next for a higher top speed. Thanks for the time and ure help.
Tyger13us
BFE,Ut
Jeff
450hp/357cid
ya need 2.73's or 3.08's for any kind of mileage,, some here will differ in opinions....
i ran an a833 overdrive trans 4sp with 3.08 and that was perfect except for it didnt have granny gear for heavy loads to get them rolling,, but i swapped it out for a 465 4sp and 2.73's which is the factory set up for some diesel trucks... 1900rpms@70mph.... it will have granny gear and the rpms will be 200 rpms higher for towing in 4th,, dont sound like much,, but 6.2's need to be in the sweet spot.. 3rd was to high for towing and 4th was to low with the a833 overdrive and 3.08.....
i had a suburban with a 6.2 700r4 and 3.40's and that thing sucked the fuel and didnt go very fast and sounded like the motor was going to blow up....
6.2s are low rpm high torque motors,, out here in farm land,, alot of farmers put 3.73 gears with a 6.2 and it will tow a gooseneck 12 horse trailer loaded through the mountains just fine,, but 6.2's dont like the rpms and the motors blow up,, ive collected quite a few...........
i would say off the top of my head your truck more than likely has 4.10's and the 6.2 will blow up really fast with those kind of rpms going down the road.....
Van-73
Delano
Ivan
I do have a spare axle from a 2001 3/4 ton silverado that I had in mind. Not sure on the gear ratio since I haven't looked at it yet. Thanks for the info by way. It makes more sense now.
If he's got a 14bolt Full Float Rear Axle, then he needs to find a 3.21 ratio rear end. IIRC, OEM in the 14b FF is 3.21 which is rare, 3.73 and 4.10's the more common ones.
Do you know what ratio you have currently? This being a 2wd, you can probably get by doing an NV4500 fairly inexpensive compared to other options. That gives you Granny low and the Overdrive too in a 5 speed.
Van-73
Delano
Ivan
I'm not sure on the ratio I have at the time...finding out the ratio is probably my next steep. My loads are not that heavy,so I'm not really worried on my granny gear.
In the Squarebody Library, there is a thread for Rear Axle codes. It also tells you where to find your 3 digit code on the passenger side axle tube. If that rear has not had a gear swap, that code will tell you what it is. Otherwise, I also have a thread in the Differential and Driveling category on how to figure your gear ratio without pulling it apart.
FenderBanger
