5.3 swap wiring help
86K1o
Farmington, NM
Andre
I need some help with the wiring of the 5.3. I already finished the harness and I'm using the stock fuse block I just need help with wiring to ignition switch. I've used the tutorial at http://www.trifive.com/forums/showthread.php?t=37085 and I'm trouble at the C1 connector. The wires that powers ignition with and powers on fuse block. Where do I splice them in at ignition switch?
duramaxcruzer
Ontario
Al
6 litre
swap 5.3
i did an 86 4x4 5.3 4l60 conversion i used the distributor feed for coils, original starter wires to starter and a 91 241c transfer case for vss and a 91 speedo to keep cluster original.
throttle out
Michigan
Sam
5.3 LS
All pink wires are switched vdc. All orange are constant vdc. Believe purple was starter signal. There is nothing else to the "ignition".
carter34
