4L80 gear engagement problems
80goldenburb
LV,LV Raider Nation capital
Nico
Suburban C20
'68 cad 472
Well since my last pot went unnoticed, i was able to figure that one out. It was line pressure issues due to a clogged, (yes CLOGGED) vacuum port that somehow had gotten pinched and was nearly closed shut. rerouted the vac hose to another port and whala, solid shifts and no shudder.
But NOW this new problem has occured. Reverse engages immediately, but putting shifter into D feels the same as Nuetral. There is no engagement unless I rev the engine to 4k. Any ideas?
yevgenievich
Place
Name
Year
Model
Size
Verify line pressure
80goldenburb
Nico
Suburban C20
'68 cad 472
well, after revving it up in Park and gettin it hot (220 degrees), i have forward gears now,and they shift fine via switches. No delays, but take off is slow. When I try to rev it past 1500 rpm it makes noise (metal rubbing) and then will go back into Nuetral, acting as if it doesnt have fluid. Keep in mind this metal rubbing noise has happened before, at any temp less than 170 degrees while giving it throttle at 2k or more to get it moving. Now 1400 rpm is my limit. Any ideas?
yevgenievich
Place
Name
Year
Model
Size
That sounds like a transmission in need of a rebuild.
80goldenburb
Nico
Suburban C20
'68 cad 472
NOOOO really?!! no im just B.S'ing.
UPDATE: changed filter and fluid, which was a bit burnt but still had a red tint to it. The bottom of the pan had some dirty graphite type substance with tiny glittery pieces. there were no big metal debri that i could see.
After i put it all back together, fluid topped and now she she SHIFTS with NO PROBLEMS. o_O ???????? :33: :anitoof: :badger_1: :banana-mario:
yevgenievich
Place
Name
Year
Model
Size
Metal sound still indicates there was some excessive wear. And the fluid does look bad. I had a 700r4 that made metal noises on a friend's suburban. It was not pretty inside when we tore it apart. It shifted just fine as well. There is no way to know how long a transmission will last after issue like that but it is going to cause more damage in long term use. Or it might just be a lucky unit for a while
jon wandvik
