468 bbc high compression
chevy79_qa
qatar
fidal
k20
460 BBC
Hello this is my second square body and it’s a 1979 Chevy k20 with a 468/4l80e(no transfer case at the moment waiting for the 205 to arrive). The 468 had some work done to it, Holley sniper, aluminum heads, intake, big cam, and pistons. The compression last time checked was 12.8. The trans is rated at 1000hp so no worries there. My question is I live in a very hot climate, Qatar. Can I drive my car regularly or just in the winter and what should I check maintenance wise regarding internals. Please note I did not build my truck I payed a highly skilled team of men to do it for me. I will upload pics and a link to the video:-
Rickf
Grafton NH
1974, 1954 & a 1937
If it was mine, I'd make sure it had the largest radiator known to mankind that would fit and use Evans waterless coolant.
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
Drive it and see how the Temps are. Should be able to drive it year round.
chevy79_qa
qatar
fidal
k20
460 BBC
I
t
You can skip the LS swap! Sweet
Yeah can’t beat a big block. I’ve got a Griffen radiator in it but temps go up at idle but will change out the fans to some from derale. Any thing I should do other than check oil and fluids?
squaredeal91
Greg bush
1991 SB
Electric fans Or mechanical? Do you have a fan shroud? Have you checked thermostat. Don't use a safety stat. Other things like drilling a small hole in thermostat can help cool it down at idle if thermostat is working as it should.
chevy79_qa
qatar
fidal
k20
460 BBC
Electric with fan shroud. Thought of doing that but will change the fans only and see how it goes
yevgenievich
Place
Name
Year
Model
Size
There is also high flow water pump and thermostat available if needed
squaredeal91
Greg bush
1991 SB
I had overheating problems in my 350 scout and high flow thermostat did make a difference.it does Lots of hot slow driving.
chevy79_qa
qatar
fidal
k20
460 BBC
I’ll check what stat it has and try that before changing fans. The oil pressure is a bit high 60 at idle. Is it because I’ve got the high volume/standard pressure oil pump in it ? What will have to be wary about when driving this car from time to time.
squaredeal91
Greg bush
1991 SB
Probably have a high volume oil pump in it. I always put one in my chevys. My 66 usually pegs 60 before it starts.
Hard
