350 or 454?
4thgentruck
South Carolina
c10 shortbed stepside.
What i was gonna do is get the rear end and front setup all off the same truck with the brake master cylindar so u know the set up would be sufficient with all the parts the factory had used one that model. And just run all new brake lines so u know there is no weak links. Just my thoughts. But just measure the front set up to be sure it will swap over
bigtalljohn13
Illinois
V20 Suburban
350ci
i just notice I enter a bit of wrong information on one of my suburbans and no one caught it LOL its a '86 R20 (not C20). Damn letters. Anyways i found a rear end out of a 2005 silverardo 2500 with 3.73 gears for $950. And also found one out of a Chevy Avalanche 2500 with limited slip but no gear ratio specs for $1200.
philjafo
everywhere
phil
k20 scottsdale
350/sm465/np205/d44/corp14
Sounds like an awful lot for used axles, maybe just my opinion tho. Last summer I bought a ford 8.8 from an exploder with 373 gears an a limited slip diff and complete disc brakes setup for $200. Granted its for a ford, so most people just look at it as scrap, but its the perfect size for my 49 mopar, but a gm axle shouldn't cost that much unless its a Dana 60 or completely rebuilt with new gears and seals an such. Just my thoughts tho, so if you like the axle and think its a fair price, go for it.
bigtalljohn13
Illinois
V20 Suburban
350ci
Yeah its a bit high, its from a local scrap yard that's quite large and they think their stuff is gold. The other local scrap yards don't have good websites.
MrMarty51
Eastern Montana
Martin
Rear brake cylinders between the 1/2 and 3/4 ton units is the same,so is the front braking calipers.JFYI
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
R and V designations were not used until 87. your 86 is a C.
bigtalljohn13
Illinois
V20 Suburban
350ci
well damn lol, i thought i caught my own mistake lol. as you can tell this is my first time owning a square :D
jon wandvik
