- Sep 8, 2019
- Northern Wisconsin
- Taylor
- K10, K25
- 400(?), 350
I really like inline 6s. with an unhealth enthusiasm. I also use my tuck primarily for moving things and snow plowing, both of which an inline 6 would do wonderfully.
And I like the simplicity. Half the upper gaskets, half the nonsense. Easy access especially in the engine bays of our truck. Never has an engine bay felt so empty despite a large V8 and an entire hydraulic setup being in it.
If i were to get an inline 6, I would do the modern upgrade where you have a manifold with 2 carburetors on it, so as to limit the distribution problems of 6 cylinders spread out for the intake.
The only issues I can see:
1) my current hydraulic drive setup. If the engine were to be in the bay, it would have to have a significant room on driver side. Nothing could go past the brake reservoir, which I dont think would. I could always move my plow hydraulic setup, but hassle is hassle.
2) exhaust.. I need one anyway, who cares.
3) transmission mating. i have the 3 speed manual with a Low gear(4 forward, 1 reverse gear) and subsequently 4wd. I dont know trans number but would anything special be required to hook up. good time for clutch and adjustment
4) mounts. no idea where they would be, if drilling, what mounts.
Has anyone done this?
And Im not only looking at a 292. Any of the factory inline 6 displacement offerings(not sure if different engines or bores, etc). Bigger is better, with sand and plow my truck has to be close to 11k
