1981 Tailgate Panel retrofit ?
440sixpack
Prineville, Oregon
dean
Is there a way to retrofit a 1981 or new tailgate panel to fit the older tailgates ? I've given up finding a perfect one for my '77 so I'm looking at this option.
Big Chip
Michigan
Kevin
C35
Are you looking for the narrow band?
Big Chip
Michigan
Kevin
C35
Right on. I can’t help then.
CSFJ
I didn't think the wide band arrived until the eighties. Are you sure the gate hasn't already been replaced with a newer one?
Big Chip
Michigan
Kevin
C35
They were big and then little and then big again.
CSFJ
Lol. Figures.
Big Chip
Michigan
Kevin
C35
The early ones had the Chevrolet or GMC centered and the later ones were offset.
CSFJ
That's odd. The band on my '79 had the Chevrolet lettering centered. Doubt it had the gate replaced, the truck was only about 13-14 years old at that point. The wear on the inside of the gate, matched the rest of the wear inside the box.
Big Chip
Michigan
Kevin
C35
The narrow bands were all centered.
Craig 85
Nashville, TN
454/TH-400/NP205
I don't think it will fit. It looks like the raised center rib is narrower on the 73-80, than the 81-87. If you're talented, you may be able to swap the backs if they are the same dimensions.
73-80
81-87
440sixpack
Prineville, Oregon
dean
That's what I'm thinking. I just don't know if the size is close enough to make it work. I need to find an 81-87 one to compare it to. I'm sure it's been tried but I can't find anything on the web about it.
CSFJ
Can you post a pic of the tailgate you're working with?
Craig 85
Nashville, TN
454/TH-400/NP205
Here's the two gates. The 81-87 gate has a taller flat section in the center, but the area is not as wide as the 73-80. I swapped beds on an '80 3+3 I had in the 90's and found out the small 73-80 trim did not fit in the 81-87 tailgate because of the taper on the sides. This why you would have to use the 73-80 back on an 81-87 style trim panel.
73-80
81-87
UNCLECHAD2021
