1976 Square drivers side A/C Duct
Randy and Easton
North Richland Hills, Texas
Randy
C-10 LWB
Installing Vintage Air in sons 76 C10. The kit has you use part of the duct for the far left dash drivers a/c vent. Problem is we don’t have that ductwork. Truck had air when he got it but that duct was not part of the existing system (imagine that?)
Found one at usa1 industries however you guessed it, backordered and date is unknown.
Anyone have an old drivers left hand duct that comes from the interior unit behind radio around steering column and out the bottom left of the instrument cluster bezel they would like to sell?
Thank y’all
Randy and Easton
mtbadbob
Montana
Bob
V20
Thank y’all
Randy and Easton
I believe they are the same through the '92 Squares. I can get my hands on one in the back of a 'Burb at a yard I frequent near me, if it's the duct work in the picture. It goes from main heater box behind ash tray, runs under steering column, attaches to lower column plate in the center, then curves up and out slightly to the lower left duct. They flex enough with a little force to install them without much disassembly. You just have to remove the lower column screw & cover. They are kinda long, so shipping may not be cheap though. Lmk if you want me to grab one for you...
Randy and Easton
Randy
C-10 LWB
If it is no too much trouble.. That is exactly the one piece I need and actually I don’t need the entire thing. The Vintage air instructions have you cut just the vent end at the instrument bezel back some and we attach a hose. let me get into the instructions and get the length and get back with you. May be cheaper to ship if we just cut it and send it then..
Stand by
Randy and E
Randy and Easton
Randy
C-10 LWB
This is the instructions from Vintage Air. It looks like where it runs under steering column there is a mounting screw and you cut the duct 1/2 inch back toward the blower..so don’t need the entire thing but will pay for it and shipping if we can work something out/
[email protected]
mtbadbob
Montana
Bob
V20
[email protected]
If you can wait a few days, I'll try to grab it later in the week, should have it by weeks end. I'm guessing it won't be very expensive, but could be $40-$50 shipped. Lmk what you think...Bob
Randy and Easton
Randy
C-10 LWB
Bob,
No rush. Not starting instal for a week and even so we can put this on the end without a problem. Keep me posted and if you want drop me an email and Ill shoot you my cell sand we can call/text to set up payment but please do it on your schedule Sir.
Dealing with a leaking carb everywhere today… looks like a new one is in his future….
Randy and E
PrairieDrifter
North Dakota
Mason
350, 350, 350, 350, 350
Let me know if you can't get one.
rpcraft
Robert
LS 6.0 364 CID
Seeing this now makes me glad I held on to that piece. I had asked around a couple of people that have done the install and they didn't seem to know what I meant. Guess maybe my terminology was off.
neiltee
San Marcos, CA
Neil
LS6
I used the ducting piece available from LMC on my 75 K10. Fit perfectly.
Chuck
I just finished a Vintage Air install on my 78.. had an extra pc that you need. Here is a before and after cut following VA instructions.. you only use 1/3 of the original pc. And yes, my cut worked fine.. an inch or two won’t matter with their flex hose and adapter. Note that my spate pc does not have the small circular vent that is positioned directly under the steering wheel.
Chuck
Randy and Easton
Randy
C-10 LWB
Chuck,
The piece I need I think is the one that connects behind instrument bezel and the actual drivers vent attaches to it correct? So the long piece with the hole in it is the section I need correct?
Randy
ChevyJGP
