Evaporator Housing Cover Necessary?
KSSB
Kansas
Ty
Custom Deluxe, Silverado
250 I6, 6.2 Detroit
This is probably an obvious answer, but I don't know, what I don't know. So here goes.
85 Silverado, 6.2, and the blower doesn't work. I ordered a resistor, switch and blower motor.
As I was looking at it, it appears the evaporator housing has a cover over it that is falling apart, ridiculously easy. Is that cover necessary, as far as needed for function? Or, can I just remove the outer cover and run the bare housing? I don't think I've ever seen one with this cover, so that would tell me it's irrelevant, but again, I don't know what I don't know. It would have to be removed to get to the motor, and I'd need to try to find another if it's required, because there's no way it will be intact if I remove it.
Thanks for the help and sorry if this is a no brainer question.
Picture? I've never seen a cover over the housing that also covered the blower motor.
Also, my blower motor started acting up and it turned out to be a combination of a few things. The power feed for the blower motor goes through the fan switch, the resistor, the relay mounted next to the resistor and the blower motor on the housing, and then into the blower. So anything within that circuit could be causing an issue. Mine would get full voltage to the blower motor, but it screamed and barely moved. It ended up being a bad relay not allowing enough amperage through. There are two relays available and they are interchangeable physically. If you get the wrong one you will immediately blow the fuse for the AC and it won't work.
KSSB
Kansas
Ty
250 I6, 6.2 Detroit
Shoot, sorry. I forgot to upload that.
KSSB
Kansas
Ty
250 I6, 6.2 Detroit
I've never seen a cover either.
I forgot to order the relay next to the resistor. So, I need to order that. This is a very clean truck for an 85, and it's lineage has stayed in the family for 40 years. So, I figured I'd just replace everything in the whole line.
KSSB
Kansas
Ty
250 I6, 6.2 Detroit
Also, do you happen to know the difference between the relays, so I know what to look for?
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
its part of the extra insulation that diesels got
Exactly. Diesels got a bunch of soundproofing that other engines didn't. I think there was extra jute padding on the inside firewall as well.
yes, hoods would have insulation regardless of being inside or outside opening probably, and regardless of trim
The resonance and drone they were trying hard to tune out, as seen by these and the intake resonator they used
They also benefitted from keeping the heat in the cab (for the ones that did that) because id imagine it can be potentially hard to keep up with the heater if your idling in the extreme cold, so the extra insulation on all trims helped keep you from being cold
I think the cold climate package, which negates the having of AC, does the same thing for the cabin and then replaces your blower fan and controls, possibly the heater core but it may just be the fan
Blue Ox
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
Yep. The price of efficiency.
The mighty TDI has three glow plug elements in the cooling system to provide defrosting in cold weather.
The engine actually rejects so little energy to coolant that it has to be supplemented.
That's some engineering $#it, and why I love Dr. Diesel's invention so much.
KSSB
Kansas
Ty
250 I6, 6.2 Detroit
That would explain why I've never seen it before. I've only ran across a couple diesel squares, and honestly didn't pay any attention to that.
I appreciate your help, and the additional information. Thank you to @Blue Ox as well. I'm glad it's not really necessary.
I can already tell, this is going to be a very beneficial forum. Glad I signed up!
I got both from O'reilly. They have a 30/40 Amp one listed or a 15 Amp. I assumed the 30/40Amp was the correct one and it was not. The one I got that was not correct was PN: RY117. I then exchanged it for the(more expensive) PN: RY23, that says it is only rated for 15 Amps and it has been working perfectly ever since. It's been about 3 years now that it has been in there.
KSSB
Kansas
Ty
250 I6, 6.2 Detroit
Thank you, SIr.
Edit: Napa has the 15 amp. Thanks again!
ChopSoup
