Gas spilling when filling up
texdave
Houston, Texas
tex
C25 Suburban
When I fill up my stock 25 gallon tank at the pump, the pump stops/clicks as normal when full and shortly thereafter I can hear gas spilling. Looking underneath, I can't quite pin point where the spill comes from other than the general tank area. Other than that, vehicle works great -- fuel gauge reads full and no other fuel delivery issues.
Crawling underneath the rear tank, I can see what looks like a vent hose that runs parallel to the fuel filler neck.
I also can't quite see if I have a 3 or 4 outlet sending unit but I can feel 3 metal lines that run alongside the passenger frame rail -- one big one and 2 smaller ones. I don't have an EVAP canister or provisions on my Quadrajet for a vapor canister purge vacuum valve - probably due to my 3/4 ton Suburban being above the 6,000 GVWR rating. Not sure if this is relevant but figured I'd share it.
A few questions for you folks:
- Thoughts on what I can do to not spill what seems like $3 worth of fuel each time I fill up?
- I'm thinking about upgrading to a larger tank (31g or 40g) since the big block drinks like a sailor (6-9mpg). Any "gotchas" or "while you're there"s I should know?
- When parked in my garage, there's a strong gas smell that my wife kindly reminds me about. Anything I can do to help with that? I've seen some DIY versions of charcoal canisters that look interesting but am not opposed to buying and installing an OE vacuum canister. I just don't know how to hook it up to my carb (T into the PCV hose?).
Lastly
Auburn, Washington
There should be evidence of staining from the gas leaking each time.
Although really hard to pinpoint while filling up. Or see up in there.
The sender looks new(er) in that picture though. Is the return hooked up? How many ports on your fuel pump? Not really pertinent to the leak but possible sources of leak.
Icbw but I thought the first several years of squares were single line, no return line, vented cap? I think that’s what my 77 half ton was/is. But my fuel system and engine have been replaced/aftermarket saddle tank on one side. So not sure what was there originally.
Fwiw, the gas smell may just be the gas cap not sealing. It doesn’t take much.
Our boat, O ring on the filler cap cracked. Could smell gas fumes in the middle of the lake but never leaked a drop.
The 77 had gas fumes in the garage, switched gas caps side to side as they fit better on opposite sides (mismatched caps and fillers), no more fumes, although the seal on one cap is now in pieces and there’s a little smell again.
Reminds me, I need new gas caps for the 77…..can’t believe that rubber didn’t make it to 50 years old…..lol
SlickGTP
Houston, TX
Mine was doing that due to some really old fuel lines that had split on the vent side of things... I'd start by looking at all the lines which probably means dropping the tank unfortunately.
I was fortunate enough that all the affected lines were out in the open. Unfortunate in the fact that the first one to pop wanted to pee right onto the exhaust. The moment I started up the truck it pulled enough vacuum on the tank to relieve the pressure and stop the leak until the next fill up.
Edelbrock
Earth
Grumba
K5 Blazer
You might be able to CAREFULLY slightly pressurize the fuel tank. The exhaust from a shop vac, air compressor, or something like that. You would want to do it outsize and be cautious of static sparks near the top of the filler tube. Then with air entering the tank, you could look around under the rig for the sound of air swooshing out. I would not park a rig in a garage that has any kind of fuel leak or fuel vapors escaping the rig. Its unhealthy to breath, and its a fire/explosion risk.
texdave
Houston, Texas
tex
C25 Suburban
Fuel pump has 3 lines, one from the tank, one to the carb, and a return line. Also, I just replaced the gas cap due to getting distracted while filling up and forgetting to put the cap back on so it's probably not that.
I have no issues with either fuel leaking when the car sits in the garage or with it starting up (2 pumps and it turns over immediately when cold) so I figured there was enough pressure in the system to keep the bowl from draining back. Still, it didn't cross my mind that there may be an active break/tear in the fuel system and that could be both the cause of the gas spill and the gas smell.
For the garage smell, it's mostly only an issue when the tank is freshly full and I attributed it to parking it soon after filling it up (and therefore still had some gas residue from the spill). Otherwise, it's just your normal hot classic car smell most days which isn't bad.
Sounds like upgrading the tank to 30/40 gallons soon is called for since I'm going to want to get a better look at the fuel lines and connections anyways.
Broken85
Cumberland, NJ
A
Just a thought, if it’s using that much gas, and you are deleting the spare tire any way for a 40 gallon tank, you could go nuts and make it a three tank system, or keep the saddle and make it a dual tank. It is just wasted space if you don’t. Sounds like that saddle tank has to come down either way. I agree, it’s probably bad fuel lines someplace.
Plenty of us can help you with this mod if you want. Pollack valve is about $90
texdave
Houston, Texas
tex
C25 Suburban
It's a Suburban so no saddle tank and no spare tire delete, it's a rear tank mount.
ASPEC
C2500
If your truck did not come with any emissions equipment (vapor recovery, air pump, etc) then you fuel tank is vented to atmosphere (open) it is not a sealed system and you will always smell fuel in an enclosed space. Your truck was designed back when gasoline did not evaporate as fast as it does now.
The picture you posted of a vent hose is just that, "a vent".
Does the fuel spill back out of the filler neck opening when filling up or somewhere unseen under the truck?
texdave
Houston, Texas
tex
C25 Suburban
There's no evidence of any EVAP equipment ever being on the rig so I think your comment about open venting makes sense.
The spill happens somewhere close to the middle of the truck, near the tank itself (so not by the filler neck).
I think that reduces the likelihood that it's the hard lines for fuel delivery or return since a leak in those lines would put the spill close to where I stand by the filler neck and I'm never close to the fuel as it spills. Potentially there's a leak in the rubber fuel hoses right off of the sending unit that connect to the hard lines. I guess I'll just use up the gas and take the tank down to inspect it when it gets low.
83Stepper
Massachusetts
Chad
Any chance at all that the return line and vapor/vent line on the sending unit have been mixed up? This could explain why it's only happening when it's being filled up. Maybe the return line on the sending unit is filling with fuel and dumping out the vent line. This would only happen when it's full because of how far down the return line goes into the tank. The vent/vapor line on the sending unit will be a lot shorter and should terminate near the top underside on the sending unit, whereas the return line will be a few inches down from the underside of the sending unit.
Radiohead
That guy on the Columbia
MCMLXXIX
C-20 Silverado Camper Special
Are the clamps on the fuel fill inlet rubber hose tight and is the rubber in good condition? Sounds like a leak where the fuel goes in the tank
texdave
Houston, Texas
tex
C25 Suburban
The hoses do look pretty old and tired, so these are both potentially in play here.
I've ordered a 40g tank + straps + hoses/clamps for a full refresh from LMC & Rockauto. Once they arrive, I'll take the tank down and get a closer look at how the lines are currently configured and the shape of the hoses/clamps. I'll post pictures and the results after. It may be a week or so before they get here.
Hard
